portare different bom
  • Thread starter Thread starter fabiovello
fabiovello
it is possible to cocreate create and fill out the distinction of details and then insert it into the complex and even export it to word and excel, what I wanted to ask you is this: Can I manage excell export in such a way as to insert values into a certain mask I created?
thank you all, hello!!
there is a goodie (load "table_export_dia") that allows to export the bom table of annotation and others in .csv(excel), text, html, etc.
Good job
Good job
How would that work? I have version 16.5 and the command you say does nothing and between the help goodies does not exist.
I use 15.50 and it works very well, I don't know for 16.50 if there is an equivalent.
I can't help you with +, sorry.
launch from command line (load "table_export_dia"), in the tool menu will be added the item "export table", the bom table of annotation is called "am-bom-data-ltab", exporting it to .csv it is possible to load in excel the tabulate file. see the image attached. I hope I've been clear.
it would be very useful to know how to customize the fields, for example to remove the id of the particular that is useless
I have 18.1 but writing that command string is nothing.
Is there an alternative command to export a table? Thank you.
I do not know if it is an additional application of the software house but when you open the separate insert menu if in the menu part I put the flag on "secondary interval", click on the "from" button opens another tabellina and I choose them export and can choose if to save the separate file in csv format.
However in general many old lisps have stopped working from version 18 onwards, some however come back to work just add string
:toolbox-button t
under the initial line
:dialog-title, for example
:dialog-title "mehrfach eigenstaendig"
:toolbox-button t
;;:dialog-control :sequential
Sorry, but I'm not experienced. .
How do I edit this file lisp?
assy/b1 : all_levels complete
am_bom_numbers:by_step:on complete
;; toolbox:
export_table
:ltabname "am-bom-data-ltab"
complete
I can't... I have version 18 and I can't export the bom table in csv
