reggio
Hello, I would need a tip, in practice I have a sort of table with a 10/15mm wide cut, in the shape of asola (like a table tool holder) and closed at the center; from the cut n°6 pins that turn chasing the profile of the cut.
what I need is qlc that prevents dust or any bread crumbs or other food material from entering through the cutting, but that at the same time allows the pins to flow freely.
even if from the drawing you do not see well, above every pin I will go to fix a plate that will make a little from "ombrello" and that should prevent the material to enter near the passage that the pin will create passing.
at first I had thought of brushes, but they are not the maximum for cleaning (the stuff stops on the bristles and then could fall equally inside) and also the aesthetic effect is not the maximum,
then I had thought about the plastic zip (http://wzxinda.en.alibaba.com/product/200121928-50254362/zipper.html), the pin would open and a slider fixed behind would close, but I do not find any article that can be fixed by bolts. . .
I have also searched without success of the double seals of rubber "combatants" ...
I need an idea and a nomination... would you have qlc to suggest?
