Mike1967
Well, give it to be the 100th post... It's not bad....:biggrin:What do you say?
I attach the file
I would recommend that you give reliable names to your designs.
For example, in the Solidworks drawings folder, you will have a twenty
of similar files that you struggle to indentify.
a good standard is to use a revision code to each substantive
change, for example you could have called that object concentric support-rev 01, now you have the chronostory of the object with
chronologically saved changes.
but, you, you have to file all the file, or just the paper??? ?
