i also need a new pc info
  • Thread starter Thread starter tekno
tekno
Sorry for the usual questions but I need advice on a new pc.
I press that I've already made a quote to the dell for a workstation, but I can't talk to someone to get advice on configuration.
I use swx with axes that also reach 500 or 600 pieces, but the problem is that I have to use axiemi derived from catia and are at 50% surfaces and my pc often freezes.
the configuration made by me is as follows:
precision t7500 essential
xeon x5650
memory 6gb ddr3 1333mhz etc-rdimm (3x2gb)
picture fx3800 1gb
hd 500 gb 7200
seven professional 64bit
that you tell me, is it too much or can it go? .
Thank you and hello.
xeon x5650
picture fx3800 1gb
hd 500 gb 7200
Hello, Tekno.
the "consists" for a new pc are good or bad always the same (at least in this time span). If you go to reread with the search the last discussions on the topic you will get info to bizzeffe.
you say you're arguing with "also" 500/600 parts.. nothing of that; You're gonna feel like 10 times a lot and more.
that configuration in your case is oversized.. even if <<grosso meglio="" è="">>:biggrin:</grosso>except the processor (that is definitely "too much", and the price confirms it) the rest goes well.
I don't necessarily see the need for xeon in your case. better a good i7 "consumer" (the series9xx, homologues of those xeon) that saves a nice tot and is perhaps even more responsive and performing if everything is set to duty. but it would also suffice one of the last two-core fast (unfortunately of the 4 cores in the cad we still do nothing).
what you save (and left!) I invested it rather in better hd (magari 2 in raid), scsi sas at 15k rpm for example make the difference.
and even that painting (as much as it is very useful a shitty vga) is exaggerated, always in your case of a 1800 you have to sell.. and it costs half.
Make sure it is equipped with excellent mobo, branded and tested, which allows you to better pull those cpus above.
and then, in fact, go to reread. It seems to me that just below you find a very similar discussion.
Here you go.http://www.cad3d.it/forum1/showthread.php?t=20307read all
Marco:smile:
Hello, Tekno.
Marco:smile:
OK thank you, the dell'I abandoned it, the pc I assemble it, if I can take advantage later I send a configuration with the procio serie i7.
I hope you have not misunderstood; the excellent and serious supplier, offers perfect machines dedicated to professionals and compared to others has good value for money with real and effective service. I absolutely didn't want you to resist that choice that would still give you assurance. I was just a soul of the situation:
and eye that to achieve performance and reliability the pc must be assembled and configured to perfection; You can do it yourself, but only if you have any idea where to put your hands, if you have some experience and technical knowledge about it. If the machine is not yours but the company (and you are dependent) and you need to work, I wouldn't mind and let professionals do it, maybe under my guidance on the choice of components.
I just changed pc
1 x corsair cmpsu-850hxeu 850w € 139.66
1 x ddr3 1600mhz pc12800 6gb corsair dominator gt cl7 (3x2gb)-- € 244.50
1 x intel core i7 920 2.66ghz 8mb box step d0 € 199.00
1 x asrock 1366 x58 extreme3 € 149.50
1 x corsair ssd 64gb nova series 2.5" sataii € 159.00
+ picturefx 5500 to € 271 on ebay in france
the cpu l have oc to 4.2 ghz with liquid cooling but it goes quietly to 4ghz air always in solid rock 24/24.
coolmaster cabinet great great but it's okay anything!
with a little money you can make a super pc!
ps: I have servers and notebooks but the pc I prefer to do it myself!!
We would miss it, the decision was mine and the boss, in some they don't make us talk to the technicians, we have to pass by a seller who acts as an intermediary, I ask the questions to her, she asks her to the technician and after she gives me the answer, it seems a little sluggish and I don't like it, that's all.
the pcs we have always assembled them. and now we wanted to go to something more professional, but now we returned to give it back, I'm sorry, it was a good pc.
Now I'd like to make a fool like this:
asus p6t6-ws revolution
intel core i7 960 socket 1366 box
kingston kfj-pm313k3/6g
memory ddr3 240pin 6gb (3x2gb) pc10600 1333mhz cas9 etc registered
pny nvidia picture fx 3800 - 1gb pci-e
western digital velociraptor 300gb 16mb sata
microsoft windows 7 ultimate 64bit it oem
returning a step back, the assemblies are not exaggerated, but they are the components that weigh, I happen to have to put in axioms that gives me the customer who inside have components built with hundreds of surfaces, and my pc does not make it, I spent a Friday afternoon and a Saturday morning trying to make a table derived from one of these assemblies and I do not tell you stress.
What do you mean, when assembled what should be configured?
hello and thanks tekno
seagate barracuda es.2 750gb 32mb sata-ii
Hi, Tekno.
definitely you will have to disable all the visual themes, leverage background and everything you don't need and kill graphic resources. Maybe put a microsd of the latest generation or a quick pen drive to make us readyboost. install the right nvidia drivers and configure them correctly to obtain a slenderness in the handling of 3d bodies but also an adequate load speed information in the video card. optimize win and all the rest is not optimize swx
hi, the problem is in opening the table, for the 3d it moves quite well, it is the passage that nails me everything.
definitely the pass is what kills you the pc. First you have to get the creation of axes and heels of centering various. then try to set the views in quality draft. In short, it should be optimized to make it travel slender even if you put a superpc.
the 3d must be 100% fluid without leaving traces and lines, it should not move to snaps. There are different settings in the nvidia control panel that make different life:finger:
the 3d must be 100% fluid without leaving traces and lines, it should not move to snaps. there are different settings in the nvidia control panel that make different life :finger:
I'm sorry if I'm intruding, like?
Wouldn't it lead to a network problem?
Look, they told me that too.
then I tried to copy on pc the contract and to work locally.
It didn't change much. said the drawing server is on the same network on the document server. I understand, but I work ijn 1 and a half, which I have to be a server on purpose?
My problem was on welded environments, which damnly takes faces on faces (unless I do not stylize profiles). :
even if not visible the hidden faces (and the edges) are "prese cmq in consideration". :
the doubt had come to me, but in theory once loaded the network should not interfere.
This is also a right observation.
I didn't make much money from local to network.
and often, when I work with the carpentry module, I also get stuck on the 2d-3d pass (with a 3d that good or bad stays fast and fluid).
for me are just unfortunately the profiles as they were built (thickness, fittings, tangences etc.).
Is it tuo pc com'è?
Now he's scraut.
2 gb of memory
picture fx 370
win xp 32 bits
hp xw6600
paid flower flower of quatrini 2 years ago.
I do not make a text unfortunately.
a day will arrive a consumer i7, 8 gb of memory, picture fx 1800 716, then I will begin to make text. without brand. and see what the difference is and where the problem will be. :
Why 8 gb ram?? so it is like "to draw him"; i7 are optimized for ddr3 that are triple channel, so to make it work as you have to go to multiples of 3:
3 - 6 - 12 gb etc.
the mobos have placed 6 "coupled" benches 3 to 3.
...I also recommend to exclude *.sld* files in the antivirus both server and pc.
this can speed up the loading phase.
Moreover it is good to keep the ws as free as possible from unnecessary programs.
I confirm on the i7 to use 3 memory banks (better to lose 2gb) and if you can buy the 3 memoirs as a unique kit certified for the trile channel.
....the possibility of oc is to be taken seriously (if done well and stable)
pass from 2.6 to 4.2ghz (4.0ghz to air) with some ten euros (150 to water and 40 for a good fan) is certainly not negligible!!!!
