claudio71
hi, I often find myself having to insert, in a side file, another part then add material or processing (typical case with the use of castings).
I can not insert in the drawing of the worked piece, a property of the original file (in case a reference to the rough fusion itself).
my purpose is to insert (it would also be enough) a note type 'recover from xxxx fusion' (clearly with the xxxx that you fill in automatically).
p.s. discarded already a priori the possibility of making a save by name of the original file because, at the change of the same, I would not have the updating of the tables of the parts in which the original (or the fusion if we want) is inserted.
How do you handle this case?
