AndreaL
Hello, guys, I'd like to solve a little problem in motion study:
how can you make the two components perfectly rigid? If you look at the file I posted, in theory the rollers should not pass because you create a small interference, it should block everything. instead you see well the two components that pass one through the other even if little. I tried to change the values in elastic properties but then they create strange bounces. same thing in another much more complex project than this.
