challenge cam to comparison
  • Thread starter Thread starter RS4
here is a first test made in agreement, because this is a type of processing that should be done in agreement only went
the second way I do not share and go back to conc. and in disc. that does not seem the right way to work
Hello rs4,
In my opinion, both for my experience, can't we trarnequalche cvantaggio?
instead working from the full wanting to realize of head and lateral zizzag multi radial level
Hello rs4,
I prefer to have quick returns and work in agreement that do not go to work intermittently conc. and discord risking to have 2 different surface qualities, don't you agree? ?
I add working from the full I agree, but only lateral I prefer in concordance
Let's say that as long as it's okay, so I hope, I agree with Count.
But if you stay on foot, today like today, who is more good is penalized and you have to arrange.
we say that we are here to be technical and we try to do things as technicians and not to sketch and send forth the production but to have the quality, the skills we have and I have it in operation, then if we have to do everything makes brodo there are moments also for that:biggrin:
What do you think
I am curious to see nx, esprit top solid delcam and the legendary pro/e in operation where you are
racing in the workmanship in agreement there are a lot of bars.. Are you sure it's okay? ?
You're right, I threw them in five minutes for lack of time. .
however beautiful and interesting discussion
Hello hairy
First of all, I apologize for my mistake in the name :confused:
you in catia or in pro/e what you propose I am curious to see pro/e I used it as cad and not cam
Hello
Unfortunately I only use the cam module ca......... I am also curious to see the cam module both of proe and nx.......
I'll just put another little exercise where I have to say catia pecca a little compared to tebis... it's about bitangency and resumption of rays....
I'm curious to see what it is then maybe we can see together
where you are lacking in the appeal:
bv pro/e, nx, delcam, auton, toptron, topsolid...... and many more
Hi, I'll take advantage of this to ask you a question.
bevelling 5 axes of a face without creating the support surface with a bevel milling cut 45° dmin=7 dmax=20 bevel 0.5x45°.
I had to struggle with my cam to get you how would you do it?View attachment Smussi_5assi.zip
more time to import than to make the path.. .
I've been able to do it with catheism, but it's really complicated.... maybe someone more experienced than me on this module knows a shorter path? ? ?
