standard material libraries
  • Thread starter Thread starter marcazzanluca
marcazzanluca
Good day to all
I hope someone can help me.
I would need sites where I can download standar trading material, such as pneumatic and hydraulic pistons, with all the fitting you need, where to download engines and what else there is to standar on the market, because in the 3d central countnet I do not find everything I need.
thanks in advance to all.
:finger:
..and of course the sites of the producers; by now many (the largest/mostfamous at least) make the material available in 3d, after a simple and free registration.
camozzi.. metalwork.. and many others for the tire.
the always great and classic skf for cuscumber and similar.
Elesa.. for various accessories.
bonfiglioli.. sew eurodrive.. motorcycle.. for engines, gearboxes, variators.
If you have paper catalogues, find all addresses on the cover.
Come on, with a little imagination (not even so much) and a minimum of engagement in google find everything.
Marco:smile:
or do you have other inputs?
I find mosaic really badly done, compared to that of sew is a jewel.
Yes, mosaic.
actually is a little "brainy."
But I'm looking forward to it. because it seems to me that at his construction he contributed someone very well known here.:biggrin:
Marco:smile:
Yes, mosaic.
But I'm looking forward to it. .
anything is better than shaping a bonfiglioli in manina.
this does not take away that mosaic "user friendly " is not, do not try to wrong the fields or to rethink the configuration because you are screwed, you have to start all over again, and do not try to access with mozilla, you arrive at the bottom having put finally all the correct fields and he makes you a pear.
if the common one (?) friend reads us, better.:biggrin:
I'm posted some links... I am more curious than a hairdresser...:biggrin:
link to the mosaic bonfiglioli you mean? Here he is.http://www.bonfiglioli.it/italiano/mosaico.htmlYou need to register to access the configurator. but you get the mail and it's immediate.
if you use iexplorer does not trouble. when you arrive at the end is "strange" the choice to make for the format to download. . test and tell us:biggrin:
considerations that apply for the first time of use; understood the mechanism I go on automatically and with closed eyes. but I had a colleague "saltuary" who for a year was not able to choose a motor:smile: (you must have clear ideas about what you need and know a minimum of topic)
Marco:smile:
someone knows one for electrical material... as buttons, switches... light spies. . .
ciao, su traceparts I did not find steel fittings (extreme type, elbow, bsp or gas) , I did not find three-phase squirrel cage engines, I also searched on the sites of the building houses, I would also need, if someone knows to direct me 3d components to design a bathroom (I found it for inventor, but do not care), they are difficult to model, and also to detect (bath, water, bidet).
steak
You didn't look well.
right because we are in the Christmas climate::http://www.tracepartsonline.net/(s(q4f40iisvojx55bnygyzjrza))/global/index.aspx?lang=itRACCORDI.webp..apart from these you find them in solidworks (toolbox) libraries, but also you have to model them to create your own library are not that great thing (I first draw them that do not enter the site, look for them, download them, compartments etc.)
, I did not find three-phase squirrel cage engines, I also searched on the building houses sites,
I don't understand what you mean.
the "normal" standard motors are with rotor to " squirrel cage". so all those you find on the above mentioned sites of manufacturers are those. that then externally nothing (or little) changes; obviously they provide you with a "exthetical" model to be inserted in your project.. Don't you think they show you real internal construction?
I would also need, if someone knows how to direct 3d components to design a bathroom (I found them for inventor, but they don't care), they are difficult to shape, and also to detect (basin, toilet, bidet) at least for me, so I don't fit.
this is not "common material" for swx (which is a mechanical cad). if you find something will be in "neutral" interchange formats (step, parasolid, iges etc.), difficult directly in native .sldprt.. maybe something in content central if some users around the world made available.
Anyway, that's simple stuff to model, it's not that you have to make them precise, you just need the size and shape around (copy them from the home, which you do a little practice.. Apparently you need it.
then try to do a search in the forum (top in the menu bar), something should be in the sections dedicated to building/architecture.
then, for everything, with the help of google and a search "open eyes", find everything you want.
you are new user to the first message. you should first read the forum rules:http://www.cad3d.it/forum1/showthread.php?t=13677..explain many things.
greetings, welcome and greetings
