seated views in photoview 360
  • Thread starter Thread starter strangelittle_girl
strangelittle_girl
Hi, I'm trying to make renderings with photoview 360 of solidworks 2010. I would like to make a rendering of an assonometric view in the section but if except the dissected model and open it in photoview the view is without section. Does anyone know how to explain the procedure?
Thank you:
Thank you:
insert the part, if on the one hand we speak, in a maximum of support (fallo also in case of together).
in the newly created set, make an extruded cut paying attention to not
to spread that function to the part/s.
you will use the set obtained to use with photoview.
:eek: thank you for the answer! I thought there was a less spartan method, but obviously I was wrong:
Thank you:
when using the command section, click 'Save View'.
after in pv360 in the view menu, select the one you saved.
