dwg files that do not open with gbg 6
  • Thread starter Thread starter flavio78
flavio78
Bye, guys.
someone can tell me why I can't open .dwg files with gbg 6?
Is there a way to do that?
thank you please
Maybe because I am dwg of a recent release.
try converting them to a previous version with dwg true view (the free autodesk viewer).
right observation.
that release should open until the r12 or 13.
I use draftsight to save backwards, possibly using dxf instead of dwg: less risk of "memory could not be read, click ok to finish the application".
gbg opens and saves files in dwg/dxf r12 so you have to make the conversion first.
sometimes it is also necessary to disaggregate all symbols and groups before making conversion
Thank you very much for your help.
I tried everything you recommended but gbg doesn't want to know about my dwg files.
I take advantage of your availability, does anyone have a manual gbg in pdf or anything else to give me?
flavio,
try reading This is files of the era of cucco beppe: if not even so, it means that your gbg is damaged, at least in its import routine.
I tried now to convert a .d to dxf file with gbg v6 and it works well, you want to try loading one of your files so I do a test?
I thank you but unfortunately I cannot send you the files because they are work files and I cannot take this responsibility.
However, my problem is the reverse, that is to open dwg with gbg and not convert .d to dwg.
Do you have a gbg manual to give me?
Thank you very much
Thank you very much
I don't have the manual.
I understood your need, I was trying to see if the translator exists on v6. you tried to use the dxf r12 instead of the dwg?
look I tried with all kinds of rescues both in dwg chw in dxf, but nothing.
the mystery is that from the client the same operation could me.
I need a manual of gbg. any version
Thank you very much.
someone can tell me how to move objects, copy objects and possibly copy quota attributes in gbg 6?
I thank you very much because I cannot find a maual.
I can't find a maual.
Why don't you call think3? I think they do.
However, to copy/seat an object:
1) select "geo" menu
2) select "translation"-- enter x-> send --> enter y --> send
3) "co" menu (copy) or "sp" menu (move)--> Select objects with window --> dx or eos key
copying the attributes between quotas does not seem to me to be possible, you can create custom formats to recall from time to time.
Unfortunately I already called think3 but they told me that they did not have the manual anymore and they advised me to ask it here in the forum.
Can I make a high-altitude style?
you're giving me incredible help thanks again
quota styles do not exist, gbg uses the pen and current line for reference lines and quota lines, and instead the default pen in the settings for text and terminators (if in the "style" tab are not set to zero, otherwise take the current color drawing).
I was referring to standard formats like "m12-n.4 to 90°" or things like that.
