emptying one part with another part
  • Thread starter Thread starter zetapres
zetapres
Good morning, everyone! !
I created a solid following a project already defined. . I have to create a mold and "empty" the same using the previously created solid.
Once you create the full mold, I can't import the solid to use to create emptying.
How can I do that? ?
Thank you so much!!
What do you mean by "importing the solid to create emptying"?
you have to do a set, place the parts according to your needs and then use the change command?
practically, having to create a hot mold, I need to draw the full article, create a mold and then subtract the article from the mold to have the "empty part" of the mold, which is then the figure of the article... :
ok, however, import the two parts into the axieme, I can not correctly place the part to remove giving precise quotas. ..because if I go on insert > component > places... makes me move the part randomly.
I would like to place it perfectly in the middle of the part that I call mold and then remove with the command that you indicated me...
I hope I have not made any confusion ;)
... I need to draw the full article, create a mold and then subtract the article from the mold to have the "empty part" of the mold, which is then the figure of the article... :
Yes, of course you have to calculate the collection of the material, so you have to increase the footprint accordingly.
I can't properly place the part to remove by giving precise odds. ..because if I go on insert > component > places... makes me move the part randomly.
you have to use non-neck "assembly", and position the piece by aligning the plans and/or the axes of the two parts.
Done! However, the problem is aligned and centred on "tools", i.e. it does not remove the affected part by changing > operations with the components > removers...because it says : "impossible to combine a placed component. recheck. "
This should happen because the components are not completely bound, be careful and see if some components are partially bound, you notice them by looking at the model tree, if there is a square next to one of the components means that it is not completely bound, so you have to add another (or two other) constraints, so as to block it in the three directions.
When asked to select the parts for the execution of cut out, you must select the part you want it to be emptied and confirm with the central mouse button, then when you have to select the reference parts for the execution of cut out, you must select the part that has to create emptying and confirm.
The squares appear like this.... hopefully see the image.
I can't understand how to give the constraints.. .
ps. I cannot post the image:(
What do you mean to 'import'?
the correct methodcorrect to place a compost is to bind 3 axes (x y z) otherwise the part remains in space and there is the risk that it goes for its own facts, one of those is that of the coordinate system.
in the modeled part create a coordinate system (then put it in the center of the piece)salvi, then create laxeme and put it in the axieme giving the coordinate sitema filter.
so doing the piece remains fixed and there is no risk that it goes for its own facts.
In your case, then, you establish the closing line, you model the closure, and through that you get punzone matrix and any movements. clearly you have to see the piece othersm it is difficult to help you.
here is the image attached :)
near the first part there is a square, while near the second there are two... :/ why?? ?
because not being properly bound the first, all the components bound to it are in turn not properly positioned.
but so I have to give constraints in the "primary" part and then have it already bound when the amount in the axieme...? ? ?
doing so for every part I realize... ? ?
I don't understand what you're saying.
create a set;
insert the first part and the constraints;
insert the second part and the constraints.
end
but do a little basic course, don't you?
I don't even know that we have to bind the piece in its 3 degrees of freedom, I think it's a serious matter.
from the good fairies, even if I understand that it causes people not to read the basic tutorial inside the program.
because dear zetapres, for this there is no need for the course, just look inside the program, we are talking about elementary functions.
the course I did it in 2008 and, for work problems, I used the software only 3 months...
only now I have put my hands back and so I apologize if I don't remember the fundamental steps anymore! !
I entrusted myself to you (i.e. this forum) because the company that sold me the program does not answer these simple questions (although I left almost 10,000 € x software+course)
cmq I managed to create what I had to do.. .
Thanks again
Thanks again
within the installation directory there is the gsguide.pdf file which is a quick guide to the use of the program.
you will find all the basic information, including the question you have asked.
I would be curious to know who you have entrusted to buy program and course ... and receive this type of treatment.
Don't tell me, otherwise the putiferous is unleashed.
I am not a ptc retailer but, I would have treated you better from the training point of view.
I didn't mean that.
there are some retailers that do not always operate properly.
I would never allow myself to generalize, it's not part of my way of doing it.
porc... Excuse me... I edited instead of listing, could you report how much you wrote, so I put the discussion back in place?
Okay, next time I'll look before I ask. . .
I'm not saying anything... it's not nice to talk about the absent :) cmq I try to arrange to exploit the investment I made 3 years ago...
