library materials
  • Thread starter Thread starter lollone
lollone
hi fellow parametric,:smile:
I decided to fix my material library.
Does anyone have one that I can pass?
This is my library.
I suggest that I have never used the parameters of structural and thermal calculation percui there are random values.
I hope it can help you.
I usually use aisi304 aisi316 aisi316l aluminum delrin fe360 c40 aisi431 bronze epdm viton nbr ptfe inoxa2 stainlessa4.
then I have another question.. .
to the particulars to trade I assign a material "trade". does not seem to me that it is possible in the material file to assign a value "0".
do you usually manage the matter? is it possible to assign to the material loaded a different weight without affecting the file in the library?
Thanks dani, always very kind!
for commercials check the material from_commercio, find it in the folder
materials, with the specific weight set at 7,85.
if then I have to vary the weight of the .prt I go in
change>set-pro-mass and add density
so I go to change the value of the material loaded and not of that of the .mat file? !
but once I change the specific weight I can't get out because the error "the material is not valid".
this because not all values to define the properties are compiled.
I don't think it works.
However to make a new material the simplest method is to make a copy of the silile file to explore resources and then from pro-and go to change the descriptions and parameters
I'm fixing some material.
in the relationship of the start I have the string material=material_param("condition")
in the .mat file I had the string condition compiled with the name of the material (after recalled in the cartiglio).
now however to fill out condition I have to enter other data otherwise it gives me error.
what relationship do you have for displaying in the material name cartiglio?
view the .mtl file name directly?
what error gives you "ptc_hardness invalid" or something like that?
if so you have to put a value, even 0, in the hardness field and type hardness.
for the rest the procedure to insert the material into the cartilage is correct
Hello, everyone.
if you can interest me for commercial use two materials "from_commercio":
-A light with aluminum density
- heavy with iron density
if instead I use a commercial component of which I know the weight, I use a material from trade to case.
then I insert in the relationships this function:
mp_density=peso/mp_volume(")
In this way I can insert the hand weight and change the density accordingly
Hello everyone
Right. Good ponies.
I fixed the density manually to get the desired weight, but so it is more professional.
This is my library.
Hi, dani,
I downloaded the material folder you made available. . . .
However, there are links to an external access file....but how do you manage the materials?
bb
Hello, everyone.
Hello everyone
hi, it will be inexperience my but I just can't find the usefulness of this... I think it's really crazy, where can you bring? Mah!
I would like to talk about managing the database of materials through access, I'm a little crazy about these things:redface:
actually if you open folders from explore resources, windows interprets the various files as access links, but if you do the same by using the pro-e browser they are material files to all effects.
as some files are a little old and in the passage from wf3, wf4 and wf5 the extension that pro-e assigns to the files of the materials, for correctness should be opened all and saved with the last version.
Let me know if they work.
