LucaMazzarol
hello to all, the company for which work produces industrial furnaces for aluminum, so often and willingly I find myself drawing with the generator of frames.
if when modeling the frame (by attaching the profiles to sketches) I use the command "inside" or "right angle" without first having extended or trimmed my profiles with the cut/extended command, the program does not update my size separately.
if I make a table of the individual profiles and quot the measure is correct, there is any scan or stretched the profile until it cut to degrees with its consecutive, but the separate measure remains that of the sketch segment I used to generate the frame.
the only solution I found is to bring the profile first to measure with the crop/extended command and then execute the other commands.
Is there any other way faster and less laborious?
Bye-bye
Bye-bye
