snaroz
Hello, friends. I found on the internet this photo of an old cosworth engine of formula 1 supercharged by two turbochargers (a 1500 cc from over 1000 horses!!!).
My questions, probably very stupid, are:
1) exhaust gases, after exiting the engine, make the route indicated by the red arrows I designed, then rotate the turbine blades and then exit the turbos heading towards the discharges, right?
2) the turbocharger propeller, rotated by exhaust gases, "resucking" an atmospheric pressure air flow that goes into the turbo as indicated by the blue arrow; Subsequently, this air mass, compressed at higher pressures, comes out of the turbo and, as indicated by the second blue arrow, goes to channel into the conduit (which I suppose is the suction one) that ends in the engine head.
I may have been somewhat imprecise in the explanation, but I wanted to know, intuitively, if things work like this.
Thank you! ! !
Thank you! ! !
