massimo3D
hello to all, I am new and I do not know if it is correct to open a new discussion but I do not seem to have found others that treat my problem, otherwise correct me, thank you... :smile:
Let's go to my problem:
use autocad 2011 with version 3d. When I create a solid quite complex and rich in elements, and then I visualize it in hidden 3d or in conceptual I create some annoying serrations. . I can't get away. if, however, the same complex object, the "zummo", and therefore I enlarge a particular, the same particular one that before saw serrated now I see it perfectly.. I put an image to make you understand better. .
I hope in your great help, thank you all.
maximum
maximum
