Steel59
greeting everyone in the area. I am trying to configure some keyboard commands in v5 cat so as to simulate what I normally perform in other environments such as s.e. and inventor. in particular I need to move to the iso view with the ctrl+i keyboard combination, to the front view with ctrl+f, to the top view with ctrl+t and so on. I would also like to switch from one display mode to another (from wireframe to shading and reverse) by pressing a single key (in inventor I use j and k keys). Unfortunately, these commands are not mapping on the keyboard but can only be attributed an alias. I was wondering if there is a possibility to intervene on some registry key or other settling to unlock these and other commands that speed me a lot if activated by keyboard through shortcuts.
I don't hide that I would also like a keyboard command that zooms me from a mouse wheel without having to buy a mouse 5 keys or 3d. the current pan, zoom and rotate combinations are impractical from central and dx key, already better with central key and keyboard but zooming with the central key pressed, taped on the dx key and mouse back makes thinking about software designers with alcoholic problems. that you can do to improve the thing without accessories, i.e. staying at the minimum mouse+key? thanks early.
