cacciatorino
I thought I would propose comparisons between our cads, chosen among those most frequently in my professional practice.
for those who will answer: attention is on ease and speed of use, not on the power of functions! Surely (almost) all the cads we use can run the tasks described, but how long will it be necessary for each software? :smile:
I have identified these typical problems, if other significant ones come to mind let me know that we add them to the list:
1) move the processing plan of a holeAfter performing a hole on one floor, we realize that we have to move it to another floor.
2) Run derived boardrun a table similar to an existing one.
3) move assiduous by variablessimulate the positions of a cinematism by changing the variables of the members that compose it
4) copy with referencesadd to a set a part or subaxieme in repetitive form, how to speed up the selection of constraints?
5) assign custom properties to partsadd the same property to all members of a set (typical: import of a step)
6) repair broken links model/tablean external collaborator provides us with models and disconnected table due to different paths, how to restore links on our server?
7) long curve patterna chain made of sludge, a conveyor belt, how do we handle them at assembly level?
8) welded-finished table managementhow to put on the table a carpentry, adding the views of the welded and the worked?
9) variable sweep on straight path
10) variable sweep on sketch trajectory
