problem with specific applied texture
  • Thread starter Thread starter Lor1990
Lor1990
Good morning, everyone!
as an exercise I am making a 3d container, but to make it real on the 4 sides I am inserting (as new materials) on surfaces of the texure...and here that arises the problem: autocad easily reproduces the texure with maps of diffuse composition and relief only on the sides front and back (or south or north hypothesize the cube for navigation) but not the remaining sides. insisting, I tried to insert the texure as if the surfaces were on the front side, in fact they are loaded normally, but just rough the surface of 90° the texure disappears. I also tried to rotate the image within the material editor, but not from the expected results.
someone knows why and how can you solve it? :smile:
Have you detailed the mapping or mapping topics??
the mapping command is what you should use, mapping type 'parallelepipedo'.
