make holes on a cylinder at a fixed distance
  • Thread starter Thread starter M.Loris
M.Loris
Hello everyone,
I am trying to make a cylinder with holes all around the problems are 2 I do not know how to insert them and I do not know how to bring them all around a predetermined distance.
Could someone show me the landscapes?
I suppose you already made the cylinder.
the holes on the cylinder you can get them with a boolean subtraction (in practice subtract from the base cylinder other cylinders of the diameter of the holes).
then brought for example on the front view and change ucs in line with the view (ucs: g, f)
build a cylinder having as an external diameter the diameter of the holes you want to do (I would start from the center of the base cylinder and do it long enough to cum over the cylinder (tube). then I would move it and duplicate in the right positions. I imagine that the holes are all radial on the base cylinder so you will have to establish an angle with which to rotate the cylinders (holes).
then take a subtract from the cylinder (tube) the cylinders (holes) and you got what you want.
sorry the pappardella but it would be almost easier and faster to do that than to turn it off.
Good job.
...build a cylinder having as an external diameter the diameter of the holes you want to do (I would start from the center of the base cylinder and do it long enough to cum over the cylinder (tube). then I would move it and duplicate in the right positions. . .
more than duplicate it and move it I would make a polar series
certainly but I didn't want to wrap myself up with more complex explanations. If he knows what we're talking about, he'll be there alone, but I think loris is "the first weapons" with the 3d autocad. :-)
Hello.
I managed to make holes on the cylinder, thanks to the answer has been of help, now I have new problem that no I find laplication, I would like to insert the quotation between the center of a hole and the other how can I do?
Hello.
Well... I think you have to make a radial quotation, that is to quote the angle formed between one hole and the other. then of course you will quota the position (long base cylinder lasse) of the holes rows or the distance of the same from the edge of the cylinder(tubo).
