smusso
  • Thread starter Thread starter varsente
varsente
Hello everyone, I can't make a bevel between two surfaces that aren't on the same floor.
I hope to be clearer with the annex, which is what comes out to me.
thanks for the attention hello to all.
Perhaps you would like to see a bevel that completely involves the surfaces without leaving the two triangles......
I don't know if I explained
That's right, you've explained very well. (other than me)
How did you shape the detail? If you're thinking about a sheet, I don't think even if I don't know the size, I might have something in mind.
the horizontal part is an extrusion, while the slope on the left is a loft.
for me you are off the road, you can't connect or bevel between surfaces.
the bevels or fittings are made on the edges, while you would like to remove that zig-zag of edges that you created, with a bevel, if I understood well.
but it is not with the bevel that you solve.
you need further modeling.
mail the .ipt file
mail the .ipt file
Sorry but I can't post the .ipt file
Maybe try first to make a nice connection in the almost planar (the one that goes towards the hole.. )
does not come because the surfaces of the loft are wintering like a shovel of a propeller.
I tried all but nothing. after an hour I throw the sponge.
the connection maybe you can model it with the fusion, but I uninstalled it.
Sorry.
Thank you for the time you lost for me.
What is fusion?
Thanks again.
nothing comes to mind?
here, after countless attempts.prova.gifpractically two 3d sketches, one at the top and one at the base of the fitting with two triangles connected with the desired size.
then with the "contour" command of 2016 the two faces of the triangles are first built and then join in one.
then with the joint command joins everything.
the limit of this is that we work with flat surfaces above and below, when instead they would need more complex surfaces of fitting, which nevertheless give me error.
Unfortunately for policy I cannot upload the file but, when I can, I can view step by step.
in any case the piece seems complex and difficult to realize (printing?). we keep in mind that these pieces actually are difficult to make with cad (or, at least, with inventor).
We could think of achieving it differently, with a different approach.
could be a good exercise
Yes, I'm thinking, "but how do you think you're doing it after you're complicated your life to shape it? "
folded sheet ? the connections between each flat part and the loft where they are?
Do you do it with a mold?
loft processing has no "condition ", at least I would give two tangences.
the sketch3 was not bound.
I took the liberty of modifying geometries, now it works (although it is not yet 100% feasible) but it is not said that it meets the needs of your project.
study the modeling system and change it according to your needs.
thanks to all for the collaboration, the piece should be made with the molding, they tell me that it should not be a problem. lack of constraints and quotas because I took them out to "lighten" the file, I didn't think about the zip.
Do you know tutorials to start 3d sketch?
thank you all good 25 April!
sure the piece made for molding will be much more similar to how it modified stefanobruno than to how you drew it.
remains the fact that from the tests done by me and others, leaving your model unchanged, inventor fails to collect that edge, I would be curious to know if other solid modelers succeed in doing so
I'm sorry, but I can't open the file.
I think it's a version problem, I have 2013
