alignment texts with the layout in the blocks
Massive, activate time sensitive, select objects, press the dx and move the mouse.
I'm doing a horny mea culpa and I'm running the shot by apologies.
I didn't work because I disabled the setting of the shortcutmenu menu (variable to 0); doing the tests I automatically disabled the check.
I confirm that the most moving right button does not work repeat last command.
maybe 20 tecnigarafo at video were not thrown away
I'll let it go because I see I write things and send them back.
1 I did not say that 20 of the tecnigraph are thrown but that acad is a tecnigraph video.
2 if you do the command as I explained and attached images works
3 first do the block then call it pippo pluto or duck.
4 I think better to let go because we talk about different things.
6 first selections then hold and muosi
7 users too base better use only acad and stay to use those
I close.
I recommend a course
I wrote a wrong courier and sprinkled my ashes on the use of the command, I thought it was enough.
that I be considered a basic user, if it is to me that you refer, but it also applies to crystal, allow me but it bothers me, especially on the indication of an misunderstanding on the operation of a command that I have never had interest and usefulness to know for my method of setting the autocad configuration, without removing that knowing even seem useless things is never wrong. .
I think I know how to use autocad well, including mechanical, above average; media that I read from the drawings that I had to have in my hands in my working path and from the average level of questions asked in the forum.
You can also recommend courses, but I think you should understand first who recommend them.
good things
plannerroad, I get clear from the post #23 image.
My mistake, which led me to a wrong statement, is that I attribute to memory the setting of the right key equivalent to sending or repetition of the last command to the specific setting of the right key, while I had really disabled this possibility (see post #41).
1 I did not say that 20 of the tecnigraph are thrown but that acad is a tecnigraph video.2 if you do the command as I explained and attached images works3 first do the block then call it pippo pluto or duck.
I close.
ics_81 a massi will not be able never work that context menu because it disabled the right-click menu in its working settings. by curiosity I made a verification, and if you disable the menu that contextual pop-up does not appear.
regarding the course council I can say that it never hurts anyone to upgrade further. But now we do not exaggerate, autocad in particular has so many twists and alternatives to get to a certain solution that not all we use, besides the working types very often condition the interface and the way of use.
I erased that post, I didn't read the whole discussion.
I have a doubt tonight and I would like to have refuted it.
using the method of using the right key to copy, move, copy as a block, error or cannot you give a starting and arrival reference?
