tanticapelli
I can now say I've done it and among other things have made me do some "optimization" exercises of distracted assemblies made by other customers."The designer must put what he needs" is Holy!
but that sentence is not foolish at all.
many times the problem is not the drawing parts, but the commercials.
I have seen things that you humans (etc. etc.) as bearings with all spheres and screws with helical threads. In addition with "image quality" (tipping, this unknown) shot at ball. or motor groups imported with fifteen thousand surfaces without even an attempt to clean the input.
about image quality, I remember that a cruder quality of higher groups non ha influsso on the accuracy of the designs and/or the files exported, nor on that of subgroups and parts.
this not always to blame the user (even because the user usually - if he did the course - applies what the dealer teaches him!) but I assure you that often the triplets are those, and once you have settled the asses things go much better.
all this is true more less for all cad 3d, with different forms but recurrent substance.
as regards solidworks, it is advisable to deepen the commands "display of asses" e "assessment", with an eye to the "graphic-triangoli" and "total triangles".
Once the critical areas are identified, one can understand where it makes sense to intervene.
because even on the parts and drawing groups, it is often enough to simplify (even hinds) only a few particular groups.
I have applied the same approach to my work but you have to recognize that during the design phases (the subject that is not held in the middle of the courses usually) it often happens that you have to turn on and off subaxis both graphically and through suspensions. These operations however require their time and serve nothing but to have a "functioning" design without too many pretensions.
then you also put the magagne of windows where every now and then asks to save everything when you launched only the drawing together and you have added some quota...
if you manage axioms of certain dimensions you can certainly adopt useful measures to "limit damage" but the tribulations do not macano, guaranteed.
and I do however for granted the use of a last generation workstation (mannaggia a questi cpu...).
so many hairs
