Martakynghi
Hi I did point 2 of this appeal verifying that it is possible to mount a conical roller bearing I wanted to ask if the design is done well
for simplicity we put on Radial ball bearings, imagining that the axial thrusts due to helical gears are very low.
calculating the radial, axial and repulsion forces of the two stages we obtain a configuration like the one below, with equal propeller to be able to subtract the axial forces.
there are negative evaluations because perhaps they are applied in the point to but on the side above the gear and arms to and there are null because the bearings are internal.
the calculation formulas for verification are these:
where for the bronzine that must not have axial load, but has only radial you have:
while for the bronzine that bears axial and radial load we will have the assessment of the axial as ring:
in addition to the radial seal as a previous point.Thank you very much. I've been studying machine construction for a few days and I'm trying to understand these bearings well. Thank you very much.this reducer carcass I would say that it has several defects and one of these is that the design of the seats, if it is complete as well as to figure has some problem.View attachment 56543for simplicity we put on Radial ball bearings, imagining that the axial thrusts due to helical gears are very low.
certainly at the school level and given the particular "simplicity" of the reducer I don't think it is necessary to shake up any other type of bearing.
the right bearing has the inner ring on the shaft and on one side of the hub. the other bearing is clearly floating axially.
If I push the gear to the right it moves everything.... if I push to the left it does not move.
solution 1 (hyperstatic)- I push the left bearing in line to the right hub shoulders.
- spacer range equal to outer ring and put it between bearing and wreath so the outer rings are firm
- to the left of the monto left bearing a seeger for tree so it does not move
solution 2 (best isostatic)- seeger holes to put right of the right bearing
- spacer between the two bearings for bearing inner ring pack
- seeger left of the left bearing
...then there are other solutions... .
my May that you used is theoretically correct but practically not because it is right that if I push axially it does not move anything but realize a bearing pack with a joke on the seeger without a shaving ring it almost certainly turns out that there is too much axial game and your tree begins to flicker.type in this case has mounted conical x-mounted radial bearings . why here are these bearings well and in the first design not?
in the fatigue sizing of the tree so I proceeded and there is no axial and radial load? So are the bearings I chose?my May that you used is theoretically correct but practically not because it is right that if I push axially it does not move anything but realize a bearing pack with a joke on the seeger without a shaving ring it almost certainly turns out that there is too much axial game and your tree begins to flicker.
sure the bearings if they are able to carry the load and have a duration greater than the desired they go well.
the bearings, apart from the purely axial ones (reggispinta) are all suitable to withstand a radial load and axial. the equivalent load is always given by the two components,in the fatigue sizing of the tree so I proceeded and there is no axial and radial load? So are the bearings I chose?
considering the equivalent dynamic load that is the coupling axial/radial forces that the bearing will bring and calculate the duration using the life formula and dynamic load coefficient c.That's why I think those bearings are good. Then the bearings are not welded, but they're stuck.sisi the nomenclature that I use is skf. in fact having axial and radial load I chose a conical roller cushion with x mounting which is also economical then I made the verification and it comes out that I load of the bearings is less than the one chosen by table and also the axial force is negligible
So are the conical roller bearings with x-mounting only that I need to fix the locks?from the site skf![]()
