Mario SJPD
with a strawberry può walk?only those who modeled this particular know how to make the bevelous one I looked for in red
You have not understood the meaning of my question.with a strawberry può walk?
I'm sure they're put to the cazzum, but they're made, you checked my step file?You have not understood the meaning of my question.
I meant there was no 2d data to create it.
If it is for real realization you can also use a 0.1mm past spherical braking with a cam.
However if the object to be reproduced in 3d is a school exercise.. Then whatever happens.
the important thing is that visually it is approximately equal to 2d.
if instead.. you have to build a 3d model and then build it really.. bhe.. in that case lacking quotas and those that are put to the cazzum
in fact your step file.. the bevel is not at 45° check it.I'm sure they're put to the cazzum, but they're made, you checked my step file?
crazy even with a frieze for bevels with a tilted wall you do not know how much, go to eye?There are quotas
11 and 18 45° = sm.3.5 for 45° on that section using a mill at 45° (only a fool would use the ball) from center ray draws me up and down exactly the profile you see,you don't need other odds and there's no other way to make it.if you use the solid sweep with the cut profile at 45° a bit larger than 3.5 you'll see that it comes to you
the initial idea was to see the feasibility of the piece in 3d starting from the 2d, that is if it was possible to reconstruct it or it was necessary the original 3d because of the complexity of the design. then any work would have been taken into account later.You have not understood the meaning of my question.
if it is for real realization you can also use a spherical braking to past 0.5mm, obviously with a cam.
if instead.. you have to build a 3d model and then build it really.. bhe.. in that case there are no quotas and those that are put to the cazzum.
There is no indication that the bevel at 45° the quotas 11 and 18 should be constant throughout their height.. or only in the a-a section.
visually.. Could be.. but is free interpretation
exactly, on your step is 50.77°Sure? according to the design of the sez aa
All you want.the initial idea was to see the feasibility of the piece in 3d starting from the 2d, that is if it was possible to reconstruct it or it was necessary the original 3d because of the complexity of the design. then any work would have been taken into account later.
14.42 ° looks like drawingYou don't know how much, you go to the eye?
Right. now, from trade, there are bevel tools at 14.42°14.42 ° looks like drawing
never thought of tilting the piece?Right. now, from trade, there are bevel tools at 14.42°
Let me understand, but what bevel did you mean to perform with the bevel tool? . 45° or 14.42°
Okay, bravo.I think you have gaps in geometry. I'll point out that if you make a quarry, like drawing 2d in question, on a cylinder shaped to 2nd and on this quarry you want to make a bevel at 2x45° constant you have to change the zeta depth of the tool path because you generate a third inclination.
