S.O.1212
Good morning to all, I hope to write in the right section.
I am struggling with a dilemma, I should make a sheet metal component, where there is both a downside and a fold as a result I would need to handle two different k things I have previously set up in the appropriate section.
only that since the surface and therefore the corner where I should bend is not parallel and the software does not bend me, and if I do it with the surfaces or with the contour flange does not bend me (bend). place an image here.
Has anyone found himself with my own problem yet?
Can you give me advice on how to handle this situation?
thanks in advance
thanks in advance
