PIETRO2002
maybe do as sketch to post 32you have thought to put two side handkerchiefs that help the ring not to ovalize and increase the welded area
[...] Let us put the case, that the soldering does not hold and there is the accident, read all the newspapers, daily there are dead and wounded in the workplace, to whom do we put responsibility?
I have thought of a thousand things and the best solution is always and anyway make a threaded hole and put on a normalized gulf. Welding should always be avoided when you can.maybe do as sketch to post 32
Sorry if I disturbed my speech, I just wanted to make a contribution and value to the discussion.I have thought of a thousand things and the best solution is always and anyway make a threaded hole and put on a normalized gulf. Welding should always be avoided when you can.
This time you can't. The object is done so, I'm not putting it on the market. It is not even a machine within the meaning of 2006/42/ce, so the machine directive does not apply. is not a lifting accessory because it is not placed on the market separately. There is no obligation to certify welding. I simply asked for help in evaluating the mechanical resistance of the ring because different formulas and fem give strongly discordant results.
Now please can we return to structural aspects?
Welding is also part of the structural aspects!I have thought of a thousand things and the best solution is always and anyway make a threaded hole and put on a normalized gulf. Welding should always be avoided when you can.
is it not considered cutting stress at point a?Hello, thank you.
correct 13.7t to yield a s275. I have made the calculation on a s235 to admissible sigma with safety factor 5, here is that the 2800kg return. so we did the same calculation even if the results appear different.
what terrifies me is that the first method and the second method have a discard of an order of magnitude. and from the image below I fear that behavior is as follows:
if the ring is infinitely rigid, points b have a tensile stress and the calculation is the one done above. Okay.
if, however, the ring is deformable and under force in the point to be ovalized, and then b continues to have traction effort but which becomes negligible compared to the bending in point a.
I did not understand this reasoning much, if it can help talking about plasticity I did a non-linear analysis with model of elastic-perfectly plastic material (s235). under some result of the last iteration that came to convergence:the difference of inertia between a rectangle 10x25 and a tondo d13 is 1,5. wll is the load that leaves a small (I don't remember how much) residual plastic deformation, we make it coincides with y for simplicity. the coefficient ks = 4 is also calculated on the break, not on the yield, so it does not have to do with the calculation that we are doing. to return to y we know that it is 2.5 times the kll reported.
If we go to report in a table the three differences with the various reports, the wll of the link to 1,600kg would coincide with the yielding of the ring to 2.270 kg. then a ton of difference compared to the fem.
plasticized regions:
the last iteration corresponds to a load of 18 kn = 1834 kgWhy don't you ever refer to cutting efforts in your calculations?I did not understand this reasoning much, if it can help talking about plasticity I did a non-linear analysis with model of elastic-perfectly plastic material (s235). under some result of the last iteration that came to convergence:
Vertical shift:
View attachment 71759plasticized regions:
View attachment 71760the last iteration corresponds to a load of 18 kn = 1834 kg
in fact the load is going up.I did not understand this reasoning much, if it can help talking about plasticity I did a non-linear analysis with model of elastic-perfectly plastic material (s235). under some result of the last iteration that came to convergence:
Vertical shift:
definitely at the base of the ring make two bevels and make welding full penetration allows to have a greater area to be subjected to traction and therefore avoids the detachment of the ring.supposing to check the ring to a cutting stress, with a tau = 4 kg/mm^, on the section of 25 x 10 = 250 mm^ a force of 1000 kg could be applied, if you smooth the ring, see sketch, with 2 bevels 5 x 45°, the resistant section becomes 5 x 34 x 2 = 340 mm^, then the applicable force , 340 x 4 = 1360 kg
I have done nothing here... is the program that considers the complex of tensions that act at every point and establishes whether plasticization occurs or not... the second image represents the distribution of the equivalent tension of von mises.Why don't you ever refer to cutting efforts in your calculations?
because the cutting equivalent sigma is lower than the equivalent sigma from moment on. Moreover the maximum sigma from moment is on the surface, while the equivalent sigma from cutting is at the center of the section, so do not add up.Why don't you ever refer to cutting efforts in your calculations?
the bevels there are and the welding is full penetration. three overlapping cords were made.definitely at the base of the ring make two bevels and make welding full penetration allows to have a greater area to be subjected to traction and therefore avoids the detachment of the ring.
se tu e @meccanicamg You don't get it, I have to be explained grossly and franticly. I try to explain myself better. we have a ring in carpentry and a normalized link. the two objects have mainly three differences: different material, different section, express load as wll = 1/2.5 times the yield. As geometries are analogous I tried to calculate three scale factors for the three conversions (the ratio between the yields of the two materials, the ratio between the inertia moments of the two sections and... 2.5) so that the product of the three factors gives me the factor of scale between the ring model and the model-link, thus putting them in the same conditions of material, section and test conditions.I did not understand this reasoning much, if it can help talking about plasticity I did a non-linear analysis with model of elastic-perfectly plastic material (s235). under some result of the last iteration that came to convergence:
Can you help me understand better? 1834 kg if I admit some plasticization? But how much?under some result of the last iteration that came to convergence:
Vertical shift:
as geometry resembles what brings 8t.to have a reference parameter, if it can be useful, I attach a page of a catalog.
