iron_mec
Hello everyone, my name is antonio, I am a mechanical engineering student, I am trying to expose a three-year thesis regarding the possibility of being able to find a possible solution regarding the case of mechanical design and sizing of the possible desired bearings, asking someone of you expert an opinion and if better also a advice for correction of the the thesis that I should expose to... and that in theory the bearings should solve with simplicity with the dynamic load coefficient choosing the right range of bearing from the catalogue suitable to interpose to the transmission shaft that peeking from some very old text of books one of the new techniques of eschmann and the other two volumes of the hoepli of accounts two introvabile texts together with that of the new techniques that I managed to purchase through ebay under the advice of my prof, but returning to the speech place a pdf file hoping it is clear to all and understandable where I place a theme regarding a check to grip of the rolling tracks the other on the auto ignition temperature on the heating of the contact slopes and a last on the possible check to slip of the rolling bodies when the speed of regime tends too to drain the limits by overcoming a certain pair of volving friction that would tend to rub the spheres or the rollers worst. I ask you, please help me find a feasibility and if you prefer a council to milead thesis...
Antonio. .
Antonio. .
