  • Thread starter Thread starter sigur ròs
sigur ròs
hello to all....for the first time I sit with illustrator.. .
I have 2 questions to ask
1. I exported the files created with autocad...transforming them into eps....as for photoshop.....have I done well? or is there a more correct procedure?
2. when save the work of illustrator in pdf.... to get the massiam graphic quality. ..salvo as "high quality" or as "type quality"
thank you in advance!!! !
Yes...because it's a restoration work... where there are millions of thicknesses and layers with retinature...I exported to eps....I change something to graphic level?
ok.. thank you, it is for this reason that I preferred to export to eps... having set all the thicknesses for months in autocad and having finally arrived to a good graphic result I would not want to start everything with illustrator! !
