14 and library libiomp5ui.dll
  • Thread starter Thread starter gerod
gerod
recently installed design space 14.0 and I find this error:
omp: warning #2: cannot open message catalog "1040\libiomp5ui.dll":
omp: system error #126: could not find the specified module.
omp: info #3: default messages will be used.
in practice the explanation is that the operating system has the different language of the program running (ansys is in English).
I tried various solutions, eventually what works is:
- download the dll.
- you create the c folder:\windows\system32\1040
- puts the dll inside and everything works.
the problem basically was this:
- a dos screen appears with those info after launching the simulation
- if you close it you lose all the simulation, including the results (you could also leave the window and save .... to me it bothered)
I hope it can also serve others and it is not only associated with ansys!
hi, the problem is due to a probable bug of ansys 14.. easily solved.. even if I went mad at the moment he showed up to me too.
simply download the file in question from the network, or libio5.dll;
creates a folder named 1040 in the path that the software tells you not to find the file and should be :
c:\program files\ansys inc\v140\ansys\bin
which becomes:
c:\program files\ansys inc\v140\ansys\bin\1040
and copy us into the file libio5u.dll
That's all.
About what I did.
My procedure works and should work for all programs that have this problem!
