torok
and he doesn't have all the twists
I'll be waiting for the day to come to the office with the help man (650 euri sigh)
and now for a year that we have gone to solidworks (now I have 2010 ) but every time we start to build assemblies with more than 200 components including toolboxes the system goes to stall for a 1-minute coupling idem to delete a component .
in one of these axioms I tried to bind a part giving a concentricity between two holes .. well I try to make it rotate and before you see the shift passes 1 minute plentiful
the machines are new of the certificate for solidworks with fx3700 picture and 64 bit view (will this be the problem?) I have already tried to restore the installation but the problems I had also with 2009.
I'm sure the problem comes from an incorrect use of the program because I don't think you understand things like that especially with axioms not large.
often and willingly in the masses of parts of large size disappear entirely the views to then reappear, as well as the lines dotted the visuals the quoto and then I do not know why they disappear (in a design I can no longer make them reappear but I have remained quotas).
always in a table I see the threads in a section view but I can't quote them in any way I close the table and here I can quote them.
are so many small things (maybe not so small) that are making me miss a sea of time
I'm not finding any complaints like that on the forum. I'm convinced that the problem is in the creation of assemblies, but I've come to a point where the situation is becoming unmanageable and I need help to identify the problem.
