2 tables, sheet cutting sets
jim78b
I have a problem as usual! I make the axis of my sheet metal cassero composed of several parts. I make the board with the distinct materials, and bubble, each part has a ball with a table number,
I want to make the sheet cut on a table apart from where the various sheets appear, the stamp but the numbers are wrong! I have to force them by hand and in the text properties I put the number...solution? ? ?
thanks and good work to all:finger:
pass for more. the bubble is related to the axieme and exists only in a certain set. we have already talked about this in the past + times and every time it has emerged that there are no valid escamotage of sure effectiveness.
you have to give a unique design code or number for each part (just a property or rather the file name) and in separate call back that.
the round will be: in the axieme see pos. 3, read in the row that pos. 3 has the code xxx and make the table by reporting the code xxx.
