244/s
  • Thread starter Thread starter sail
Who explains to me what "float" means? (exatem, obviously I have it mainly with you...)
I'm... I'm ashamed.
15km...what thread is it? size? weight? What's in it? information? power?
If the spool is on the torpedo, I imagine that the thread does not make any resistance, because it is "flow" than water...right?
but for the enemy not enough to intercept the wire to put ko the torpedo? and to mate with a wire of a few miles is not that it takes much... the coffee key works so... where am I wrong?
threaded means that from the inside of the submarine it is possible to "drive" the torpedo on the objective thanks precisely to this " umbilical cord" represented by an optical fiber cable.
in a philanthropic torpedo the "guide signs" travel on very thin optical fibres contained within a sheath, connecting the "fish" to its pointing system. in the navigation to the target the torpedo releases behind if the guiding threads that are contained in its back, thus allowing the "pilot" to send corrections to the trajectory.
These are sophisticated weapons in which digital information flows in both ways. I'll explain.
- from submarine to to torpedo travel the commands on course and altitude, the submarine guides the torpedo in the area where it is believed to find the target.
- from torpedo to submarine return information from the sensors mounted on board the torpedo. the torpedo, thanks to them, reports to the submarine the situation regarding its position, contacts, etc.
We're on board a submarine and we've "snapped" a contact.
1. the submarine analyzes the data processed by its sensors to find the exact position and motion (hijack, speed, etc.) of the target to attack; Once safe, pass the data to the torpedo (through the thread) while the torpedo is still in its launch tube.
2. the torpedo is launched and begins its race towards the waypoint that has been set to him; the wire is quickly unrolled by continuing to receive orders (course changes, altitudes, etc.) according to the tactical situation leading it to the target.
3. when the torpedo, thanks to its sensors, certainly signals the smg to be close to the target, the smg activates the procedure of attack of the torpedo (from this moment the torpedo is only and follows its program). If something goes wrong, and the wire is always hooked, the submarine can regain control of the torpedo at any time.
if the thread is interrupted (for example breaks), from that moment on the torpedo keeps the last order received and follows its program.
for the rest explained "the aviator". :biggrin:
we have drawn from the same "supplier". . .
I'll explain why.
when the topic are weapon systems, especially of last generation, the risk of treating confidential arguments is quite high.:cool:
then to not miss, it is preferable to report as already public domain on any website easily accessible.
are fundamentally the same news that can be found on the sites of the companies producing or on any magazine in the sector (for example).
Ultimately they are "precautive plagiarism".
Maybe yes and maybe not, I took my information from the network.......... but not from a magazine:tongue:
a question...
How much does a torpedo cost?
la wass should have won a €87.5 million order but I don't know exactly how many pieces we talk about.
As an example, however, the American m48 in 1978 cost $894,000.
today in the adcap version costs $3,50,000 each.
Fucking cow!
I mean, you're on the ship, you spot the enemy, dots, shoots and throws him at $3 million and a half dollars?
that if the other one uses a half million dollars in countermeasures, your little prologated economic nouvre is also a cilecca?
But don't you want a nice assembly like you did a couple of centuries ago?
Fucking cow!
Yes, with the saber arranged between the teeth and the parrot on the shoulder...:biggrin:
President would use a walking stick and a parrot on the wheelchair!
This parrot, though...
ibis redibis non morieris in bello.. .
You mean:
"er president would use a walking stick and a parrot on the wheelchair!"
or:
Who's on the wheelchair? the parrot or [solo] er presidente?
You mean:
or:
Both on the wheelchair!
if the president was not on the wheelchair, it would not make sense to him to use this parrot
Even if there was the only parrot on the wheelchair, it would mean that the president is scattered without the same, which is clearly and notoriously impossible:
logic leads us to understand correctmethods despite it is ambiguous in the form :mixed:
