Sil_sil Guest May 3, 2023 #1 Hello, everyone. is there a way to get 2d views from a 3d model using autocad lt? Thank you. ♪
dieva Guest May 4, 2023 #3 Sil_sil said: Hello, everyone. is there a way to get 2d views from a 3d model using autocad lt? Thank you. ♪ Click to expand... You could try with the command wmfout, applied to the model with hidden lines (seek command) and subsequent import with the command wmfin. nb: the dimensions of the geometry obtained could be slightly approximated than the original.
Tristan Guest May 4, 2023 #4 dieva said: You could try with the command wmfout, applied to the model with hidden lines (seek command) and subsequent import with the command wmfin. Click to expand... used once million years ago. I spent hours cleaning the result from the hundreds of useless lines that were created. but in the absence of anything else...
