3d configuration mouse connection - rhino
  • Thread starter Thread starter jt_cad
jt_cad
any of you use 3d mouse with rhino?
you can configure the keys (I have the version with two buttons where you can assign 4 or 8 radial commands) with rhino controls?
If yes, someone did, and could help me do that?
Hey, you can do it quietly.
the first thing is to assign the "fast keys" (keyboard combinations) to the commands of rhino (if you haven't already done) that you want to recall with the radial menus.
then configure the radial menu of the 3d connexion according to the indications of this video (even if it speaks of the spacemouse the configuration is equal for all products). you use "keyboard" of course, not macro... you can customize every program you use with its dedicated shortcuts
I took the spacemouse with the wire and 2 buttons for left hand... a bit of stun at first but after a period of roding (long) I no longer know how to make without it and I forget very often the use of the keyboard (apart from inserting numbers/texts or particular shortcuts) ;)
Hello archimede, thank you very much for the video!
After I look at him and I see how to configure everything.
I'll ask you for help! ;-)
below the watch shows you the 3dconnexion running program? if you click above (dx key) should appear "open 3dconnexion property"
there are two types of programs for the 3dconnexion (now a good memory) but one with black icon and one with white icon (it seems) and are with different features... check their site is all specified
Do you recognize the 3dconnexion? in the menu 'Rhoino options' should appear " 3dconnexion buttons" (my appears between "inactive process" and "rendering")
in mine is:
_spacemouse _popup_menu
_spacemouse _zoom_extents
