Abbe
hi, I press that they are "ignorant in the matter" and I'm not sure that this is the correct forum; I try the same.
I wanted your help to solve this problem:
I have to build a model of car in scale 1/12 using for the body shop a system of stereolitography. I basically need a .stl file of the object in scale. on some 3d modeling sites I found the 3d model of the car in 3ds format. what I need to know is if you can switch from 3ds format to something manageable with autocad or rhino to be able to integrate it and then download it in the final format. also how the size works in 3ds, can you scale the model?
tree
tree
