3d modeling - solid sampling on sections
  • Thread starter Thread starter Cla
Cla
hello to everyone, does anyone know how it is possible to see the sampling when making sections in 3d?
Bye!
that I know in 3d environment (part and assy) can not.
However, if you need images, you can set a section in part and assy environment (command in pmi menu).
in the table put the view you want and put it in "shaded with edges" mode, then go to the properties of the view and activate the section.
hello and thanks for the answer, for the table ok, I am accustomed to other cads (cree, proe, catia) in which the section is visible also in the 3d therefore I thought the same for solid edge ... see if others may help me. Thank you! !
