graziano-g
I'm finding a strange 3d scale command behavior on 2015
in practice I can't select one axis or one plan as described here:
http://markknight74.blogspot.it/2010/07/scala-3d-comando-autocad.htmlor here:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/cloudhelp/cloudhelp/2016/enu/autocad-core/files/guid-e96829d6-a58a-48b6-8b65-a7c99c879262-htm.htmlif I click on the xyz check start the command then I can't uncheck it to switch to a different variable like just one plane or only one axis, same thing if I try to isolate an axis or a plan, select only the center then start the scale on xyz
Any ideas?
some distrustful variables??
Is it possible that the command only works with mesh even if I don't think I have read this limitation anywhere??
Any ideas?
