Good morning to all,
I was trying to realize a 3d parametric lock of a slide using a simple escamotage, but I am stuck on the last aspect or on the width adjustment of the upper frame. how would you solve?
for the moment I have solved by replacing the loft series between regions with lofts between lines that can be ironed, but I would still like to know if the first version is systematic.
allego updated and completed version
3d parametric blocks in autocad have huge limits and no one uses them. then you are free to do whatever you prefer, for charity, also use a pan to plant a nail because you do not want to buy a hammer.
If it's a job they commissioned you, it's another speech.
I'm sorry, I didn't want to argue.
ok, however you are out of topic because the discussion is not to find the best software that already has the parametric blocks but to understand if there is solution to the problem highlighted.
The blocks are doing them for me and for those who will find benefit.
