thank you, unfortunately I tried with propeller but I can not handle it and change it. then in reality the spiral is formed by 3 circles and I don't know how to intersect.You could build a horizontal plane and rotate it in 3d on the z axis, but if you cut that figure with a tilted plane you wouldn't get the result of the image you posted with watsapp. You would have a result like that of image 3, which I don't think correct.
rhino will surely have the command "elica" (or spirale3d) (I use autocad, but surely rhino has a similar command)
It is better to build an helix (or spiral 3d) with a radius on the lower base and a radius on the upper base, as a number of coils about 1.5, and a height. then extrude down the newly formed spiral and cut it to the base. After that work on that figure to do everything else
something like that:
