3dexperience (catiav6) - macro pulsating
Sirmione87
hi to everyone, it's the first time I write in this forum.
I need help. I'm modeling with icem shape design.
within some commands there is the possibility to enable a different display mode.
I explain better, you can set from this drop down menu 3 possibilities static dynamic and none.
these three functions differ in how:
dynamic: when I have to move a surface through the control point (control point) it gives me the possibility to dynamically see the elements that are updated very beautiful, but with an expense of many performances by the processor and graphics card. (impossible to model because of the lag),
none: I make a change and only and exclusively when I press the apply command I see the processing of the object.
static: last but not by importance allows to move the surface and to see only the release of the same, the modification made.
returning to my request, I would like to create a macro to integrate this function on all commands, so that they do not work in dynamic. I have attached a screenshot to highlight my request.
p.s. the manual update mode does not respond to my requests, because I place sections globally.
Thank you very much for your help.
simone
