3ds
  • Thread starter Thread starter Nibor
Nibor
Hello everyone, I wondered if with rhino there was the possibility to export a 3d model with all the textures used, and to open it with 3ds ... in any way how it should proceed to insert a simple texure on a geometric object on 3ds?
thanks:finger:
I managed to insert the texture into the object saved in 3ds by rhinoceros though, the texture does not spread me in a homogeneous way in the solid !!! but the texture is divided into surfaces ... can I get a homogeneous effect without these subdivisions? ? ?
I managed to insert the texture into the object saved in 3ds by rhinoceros though, the texture does not spread me in a homogeneous way in the solid !!! but the texture is divided into surfaces ... can I get a homogeneous effect without these subdivisions?? ? Thank you.
ca.webp I attach the file of the unsolved object
with 3ds does not improvise....if I can afford, I suggest you buy a manual or follow a certain amount of tutorials before going to do certain operations (although they are simple imports from autocad or rhino). There is no magic button that pressed solves every problem.
If by disgrace one morning I drive and turning the key doesn't happen anything, I'm not even opening the hood because I can't do anything but look inebetito the engine.
to do what, hypothetical, you want to do you need a minimum of knowledge of cause
This uncertain arid and unfaithful Filipino could have saved her, there are other cures for repressed acidity, not that of vilipendere and vitupering people...
try to do this, step by step:
- import your geometry
- dx key on geometry : transforms polysurfaces
- select the polysurface and apply (from edit panel) the uvw
- apply the material with the chosen texture
- various uvw parameters to adjust the texture
ps: In some cases it may be necessary to do this for single face of your model.
Are we sick, huh?! no Filipino, just the reality of the facts. If you're upset, it's just your problem. Good job
:finger::finger::finger:
thank you so much marco you have been clear and concise
I solved the problem of texture and I
obtained the desired effect
Thank you very much
if I save my file with textures in other formats so that I can be opened by other programs as never recognizes me the texture but only the volume of the object?? ? is a texture seenlized only by the program with which I created it and applied it?
