3dxml management
  • Thread starter Thread starter Dum
Dum
I'd like to ask you a question.
Is there a way to avoid that all times except a product in which I placed a 3dxml, the folder fills me with .cgr (which I imagine are the various "components" of 3dxml)?
I hope I've been quite clear.
Thank you!
:finger:
When you close the 3dxml you don't save the cgr...
in case you have to use 3dxml in another product, from manageable self-saving rescues without saving cgr (of course you will not be able to save the product father, but the children or the parts you do.
Hello, please.
When he asks me to save the cgr, I clearly tell him not.
but I only do this when I open the 3dxml, I see it and then I close it.
but when that 3dxml I need in the layout, so I also have to save the product father, I did not find way to save the cgr.
It's not possible, is it?
Thank you!
As I imagined, you use 3dxml in another product and so I think it's just mandatory to save the cgr...
everything depends on your use:
If you need to step into the 3dxml tree, the road is that
if you need it as an "image" without intervening on the tree, save it directly in cgr at least you have only one
I don't make trouble and always load the big assemblies in cgr (by generating cgr cache to load) and then I double-click only the parts I need.
or I manage hides and displays, explodes etc. through advanced scenarios.
Try telling me what you do with the layouts we see if you find a way.
Hi, gianni,
thank you for the patience with which you always intervene in the post.. :
Like you said, I need it as an image.
I'm thirsty to make sure there's no weird stuff I can go into conflict with my projects.
and clearly I always care because I turn to the client studies so that he can have a whole vision of the project.
I had never thought of saving it directly as cgr.
I'll do some evidence, but I think it's the best way. .
Thank you for your patience!
instead I would like to do the opposite... .
I would, once opened the 3dxml, save all the connected cgrs.
How do you do that?
to me in rescue management do not appear... me or r18.
consider that I load in a product a 3dxml file but if I manage save it makes me see only the two products and not the associated cgrs.
or is a problem of version or settings I don't know.. .
Anyway:
if you save the product with the 3dxml file do not lose it, you can continue working and should not be necessary to create the cgr
if you lose it (or if you want the cgr) save it as cgr.
Let me know.
the problem arises when I open the product where 3dxml is loaded.
in fact does not find the connected cgr.
to view it first I have to separate open the 3dxml (and then load the cgr that I do not know from where it goes to fish...I think they are intrinsic of 3dxml) and then open the product that contains it.
I can see everything at this point.
only happens if you mess up the rescues: if you do not save correctly with saving management, create product and 3dxml with same name or an empty 3dxml and a full in different directories, so the loading seems empty, but open (part) loads the object.
try to do a search in windows with the name of 3dxml and see how many and where you find it.
however it is not serious: charge the product and delete the 3dxml, save everything, close and reopen then enter the 3dxml again. in rescue management keeps everything in separate and saved folders.
let me know.
hi.
I'm sorry, but I'm talking about 3dxml.
I know what they are but they are never used by us.
what are the advantages of using them?
if he can be ultile, if he talked about it quievery now and then I use it as an exchange format for the supplier, in order to provide only an "image" of the project.
However it is not serious: charge the product and delete the 3dxml, save everything, close and reopen then enter the 3dxml again. in rescue management keeps everything in separate and saved folders.
Let me know.
I try to explain all the steps, because it looks like a cabbage, but I can't.
I press that my goal is to create a set that has all connected cgrs, that respects the tree of the original product and that I can turn on and off all composed, for a demonstration display.
the original product being large is more difficult to manage.
Okay!
I open my .catproduct and save it in .3dxml format (rename it).
I close everything
I reopen my .3dxml by loading it in catia
at this point I have my product opened with many cgr that have no connection.
at this point I want to save everything in .catproduct and consequently save all ex .catpart that in 3dxml xono divantati all cgr.
I stop here because if I save by name or if I go to management save these cgrs to save I don't see them.
I'll be sorry, but I'm not getting it, but it seems a trivial thing, but I can't
in addition to what has said railroad, I add that unlike saving a product in cgr and getting a single parent file without being able to see the children, the 3dxlm retains the tree structure, with the possibility to view the names of the parts, revision, nomenclature, definition etc., and to be able to hide/visualize or change graphic properties of each part (and is very light).
this in very complex products can be useful.
Because it looks like a cabbage, but I can't.
It is not you, I imagine that the problems are related to the 3dxlm or the revision of the casket you use.. .
I believe that the 3dxml was born in order to provide a supplier or customer a light display format, while for those who have catia it is better to use directly the cgr.
I abandoned the 3dxlm in the products, besides the fact that it filled the cgr folders, it is never updated to the last state of the project!
much better to use cache cgrs.
(months/options/infrastructure/product structure/caching management/caching operations)
wanting you can centralize the cache on a server so you can use it with all colleagues.
