abaco graphic infixes
archfloris
Good morning!
is it possible to create in revit 2013 a graphic abaco of the fixtures?
I realized the table with the automatic command (abaco infixes) and now I would like to insert simple 2d views related to each type of infix.
with my current knowledge I would create two views (vertical section, horizontal section) for each infix, and then I would embody all this in a table along with the abacus (table) of the infixes.
But I don't really like to fill the file with an avalanche of views.
Is there a cleaner method? and maybe even faster and painless?
you can create a legend (you can find it in the view card) in which to insert views of the plant / prospectus delgi objects you want (windows-doors etc). set the scale and insert it into the table as any other view
Thank you so much!!
That's exactly what I was looking for.
I take advantage of it to ask some further questions:
can you insert at the same time views of prospectus and plant of the fixture in the legend?
to indicate the name of the infix, mark and size is it possible to associate a parameter text in the legend?
when inserting the legend component, from the property bar curtain choose the view, which changes depending on the component you enter (plant, section etc.)
Here we gohttp://www.cad3d.it/forum1/showthread.php?24129-compilare-la-legenda-di-revit
