academic licenses - i can't open permanent license files
  • Thread starter Thread starter Cla
Cla
good afternoon, I would like to ask for advice because I happen to receive files (always made in solid edge 2023 by some students) that I cannot open (with if 2023 permanent license), you know what is the problem and if there is a way to open them?
hi, files created with the student license (and also with the community) are not openable with the commercial license.
hello and thanks for the info, I thought it was the opposite.... At this point I should like to install an academic license I believe, how does it work (to whom do I have to ask) and what limitations does it have compared to commercial? Thank you.
you can download the community license solid edge community edition with which you can also open files created with student license.
the main limitation is that you cannot use it for commercial purposes (buy money)
I advise you to use both academic and commercial versions within the same lan. siemens will prove that in your office both are used, and so it will assume a misuse of software.
if you just have to evaluate the work of a student you can send a step or parasolid, if the student version previews this type of export. If it is not possible to export then it is better that the educational version uses it only at home and possibly on a pc on which you have never used and you will never use the professional version.
hello to all and thank you for the advice.
I downloaded the academic version and removed the other, I hope I have no problem... but in fact money zero :d
I take advantage to ask one thing, between academic licenses there are problems of compatibility between files? I should check better but I had problems opening some files made by students (using the same type of license).
thank you again and good first May!
What kind of trouble? Could be a version compatibility speech, or some of your students used a commercial license.
it is not possible to open saved files with a newer version; This is always true regardless of the type of license.
Moreover, having the software installed to switch from academic to commercial and vice versa it is enough to change the license file through license manager
I noticed after having a different version and I believe (99% of the odds) is that the problem.
Maybe I misunderstood, under the 2310 academic license, can I manage files that are compact to the 2210 academic license without having to reinstall everything but only by changing "something" licensed by license manager?
Thank you! ! ! !
yes exact, opening the license manager, I would go to set which license to use; This way you can switch from academic to commercial and vice versa without having to reinstall solid edge.
said this, with 2024 academic you can open files created with academic license on version 2024 and previous; with the commercial 2024 you can open files created with commercial license on version 2024 and earlier.
