Yes. in view properties, "underground" field select the level you want to view in transparency.
attention to correctly select active level objects and not the underlying one
if you create a problem, turn off (cut) temporarily the view below.
Otherwise, clarify your problem better.
p.s. it is appropriate to always indicate what result you want to achieve, because according to the result, the solutions can be different.
by highlighting only the problem, outside the context of use (what is being done and the purpose) , does not make the correct framework necessary for the resolution
