adapt the old macros to the lever v18
cacciatorino
the need sharpened the ingenuity, and, in view of switching to v18, I sprayed a little on cad.de to see how to operate the old model macros also on the new interface of v18.
obtained the result, I share with you a quick manual on how to do the operation.
I saw some interesting things from 18.1 but who knows if I will ever use it.
hi I just installed version 20.1 and I have a set of macros that I would like to have available at startup, without having to go to every restart in the server folder and drag me into it.
I think that in the explanations of pdf is implicit, but being me just fasting how the lisp works (I just charge them and use them) I kindly ask you if you can know the extra steps to make the lisp that interest me in that menu appear at the start.
thanks for availability
to make your macros appear in a personal menu, you need to automatically upload them to start, then create your own custom menu...
1 - insert in the sd_customize file of your local installation the files of your macros to upload.
2 - create a macro file where you confiscate your personal menu.
in the modeling help file see ...documentation/integration_kit/examples/fluent_ui_lsp.html?queryid=168b9006324
