tvi71it
Good morning, everyone.
I created time ago a drawing, starting from a product with dozens of components. at the time of drawing creation I had selected from the product only the components that interested me for the realization of the design. Now, a few weeks later, the product was modified, one of the components I had selected was deleted and another was inserted in place. clearly when I go into drawing, the pointed document is correct, but it turns out a broken connection just with that component that was deleted.
in "modification links" of the view, after reporting that I have to delete the broken link, in order to proceed, I saw that there is a box with "3d elements to add" ... if I could add in the view the added component .... I'd be fine. I did some tests but I can't add it, because the 3d element box to add is always empty...
Do I need to remake the drawing?
has this problem already happened to someone else?
thanks for any suggestions.
tvi71
tvi71
