add climbing plants to fences
  • Thread starter Thread starter piccolo geom.
piccolo geom.
Hello, everyone.
I'm designing a factory for civil use, and for this building I need environmental advice. ...
so I have to make renderings to insert this property into the context where it is located. I should insert to the fences of climbing plants to camouflage some such fences............
I would like to know if in revit it is possible to do this, and also how could I do all this??? ? ? ? ? ? ?
Thank you very much.... .
Okay, thank you. .
where could I find aluminum windows families (with shutters)?? ? ? ? ?
I found some of them but they are not similar aluminium windows.
Yes, I found only one kind of family that can be okay, only that doesn't change the color even by changing the family...... .
open the family....gest>stile of objects....you will find a series of subcategories, serve to manage the appearance of the various components of the family.you can set thickness styles and even materials, try to change them from here and see if you apply them.if you upload the family into the project and set the materials you need from objects styles.
ps: it is not said that parameters are always created to manage materials depends on the need of the creator subcategories can be a solution.
