windreef
Hello, can you add new types of belt generator? also because those available are only h and l and t, they would miss at least the metrics 8m 14m ect.
Hello everyone
Hello everyone
if there was a possibility to make a copy of the straps in the database of des. acc. then you could manually change the data. Boh? I'm going to miss you some time.ciao!
al follower post
http://www.cad3d.it/forum1/showthread.php?p=69633#post69633I asked for help on the same problem in inventor library folders there are files in html that contain the parameters of straps and which are used by acelerator design... I threw out a couple of days a year and broken ago... but I did not ride a spider from the hole...:biggrin::biggrin:
