add rows and merge cells in a table
  • Thread starter Thread starter pelle_pelle
pelle_pelle
Good evening to all, I am new to the forum and I would need help. for work use autocad 2006 lt and I need to change a table I created, adding other lines. Another thing I have to do is to join two cells together. Can anyone help me?? Thank you so much in advance!! !
I do not remember in the 2006 version the management of the tables.
in 2012 you can join by selecting the cells to join (after selecting the first, for the next you have to hold down the capital key) and then with the right click option "unions"
for inserting rows just select a row and always with the right button there is the option to choose whether to insert it above or below.
with the latest versions however the management properties of the tables have changed. Maybe in 2006 those possibilities were not there.
Thanks for the help. even with autocad 2006 it is possible to change the tables, I couldn't because I had set wrong the function of the right button.
